compression fittings
21 Mar 2007
Cheshire
do i need to use jointing compound on the olives when using compression fittings ?
no.
just clean the copper so it's shiny before you add the olive.
If conditions are perfect then bare metal will seal just fine.
As a precaution, some people use compound, and others like to use PTFE tape.
Note that the MIs for large gauge (>=35mm) compression fittings recommend light machine oil on the threads, so you do the b*ggers up. :shock:
