Good morning all,
The flush valve on my bog cistern is sticking open, I believe it is the switch for some reason placing too much tension on the cable and jamming it open as without the switch on the cable the valve closes properly. Regardless, I don't think I can change it separately so it all needs replacing (valve, and cable flush switch).
I essentially have one of these in a wooden box behind the toilet:
Inside is a canister valve very much like this, which is plumbed directly to the white pipe coming from the bottom of the cistern:
So.... The cistern tank and fill valve are fine, the flush valve is knackered. I've seen similar replacement valves in screwfix etc, but I don't know how the bottom part of the flush valve would attach to the curved white pipe coming out of the bottom of the cistern.
Are there differences in the flush valves depending on whether you have a cistern attached directly to the toilet pan or if you are planning to attach it to a concealed cistern with a pipe connecting to the toilet pan?
i.e. if I buy this (or similar, links appreciated!):
http://www.screwfix.com/p/flomasta-push-button-dual-flush-valve/1266f
How much of a pita will it be to fit to my existing cistern?
