I have been spending hours trying to work out how best to tackle this problem and am looking for any advice.
I am tying to repair the ceiling of the bay window in my lounge. It is made of a slab of concrete which is tied into the house. There is then a layer of plaster which has crumbled away in the outside corners where water was entering. I am then only left with 25mm to play with before the windows. There were polystyrene tiles glued to the plaster previously.
When I first moved in I had it re felted to stop the water entering. Having read up on the issue I can see it would have been best to insulate on top of the concrete but I am loath to do this now.
I have read I need a layer of insulation followed by a vapour check such as foil backed plasterboard. Is it possible to get both of them on with the limited space I have? Plus how on earth do I go about fixing them? Could I use an adhesive and prop them up until it's set?
Any advice is much appreciated.
