Concrete Shed Base Cure Time
8 Mar 2014
Hampshire
Today, I've made a 12x8 shed base using 1" MOT under 2" of concrete (using bags of pre-mixed stuff).
Someone who knows about these things popped their head in and said I've laid 'half-dry'.
It's under a tarp now.
So am I good to build the shed on it tomorrow?
One inch of stone and two inches of conc is a wee bit on the lean side.
However, if the shed has its own well supported plywood floor then you will be ok.
If it was your intention to use the slab as the floor and as direct support for the shed walls, then your base may struggle.
