I'm building a base for 4x3m log cabin (fancy shed) and intend to sit it on 75mm-100mm of concrete which will be poured into a form which is raised above hardcore using stakes.
The hardcore is old bricks & concrete which I have sledge-hammered down to about 5-7cm pieces. I want to put a DPM before the concrete, but need something that will be flat and level so I don't piece the DPM. I could use, MOT Type 1, ballast or sand and now have two questions:
1: How much extra MOT Type 1, ballast or sand to account for gaps in bricks? I can use an online calculator to work the amount, but a fair amount will sink into the cracks in the rubble and that is the difficult bit.
2: Do I need to hire a wacker/ vibrating plate? I do have an iron tamper bar.
