We have just had a new boiler fitted and the condensate waste is a small bore white plastic pipe which has been run outside and then along the outside wall to join up with the normal sink waste outlet, however the two pipe sizes are obviously much different. The sink waste is a larger diameter grey pipe. So the guy fitted a new Tee piece which is white and then put some grey pipe lagging on the small diamter heating waste pipe.
In my opinion it looks poor, I would have thought it woulkd have been better to run the CH waste inside the cupboard to the sink waste, or at the very least use a similar type of pipe to the existing waste outside.
Is it normal to use laffing on outside pipes? Is there anything I can do and is this a valid complaint?
Ta
Ta
