I'm after some advice.
I have a property with 2 soil stacks; one on each side of the house. Both internal, they run straight from ground level up to the loft with the relevant connections.
Once in the loft the 2 soil stacks are joined by a horizontal soil pipe laid across the ceiling joists. In the middle of this is a single soil pipe that goes up to the apex of the roof and fits within a steel shroud. The vent is on top of the apex.
I'm getting rather significant moisture from condensation forming on the roof felt and steel shroud which is dripping down onto the insulation and plasterboard below. This is obviously much worse in winter and also after someone has a shower.
Is there anyway of modifying this to stop it happening.
The house was built in 1986.
