I moved in a a rented flat in a newly constructed building 2 weeks ago. There is a laminate flooring in the flat.
In the utility room, there is an interrupter that reads "Extraction". This interrupted was set to off and the landlord didn't mention it when I moved in, I didn't even know it existed.
As it was cold, I started to put the heating on the first week. And suddenly I started to notice condensation as there was like water on the windows. So I started to open the windows to make it better.
Three days ago we noticed that in one area of the flat, the laminate flooring started to bump/sweat and it now looks damaged. It's only one small area but the landlord says it is because of the condensation and that's because the "extraction" interrupter was set to "off" because he says this stopped the air circulation in the flat, and also he didn't find any leak. He blames me for this.
I have 2 questions:
1) I read that condensation can indeed damage a laminate flooring but is there a way to confirm this is the reason? I reckon that after we switched the interrupter to "on", the condensation problem got much better. This interrupter actually controls the air and I can feel now that it's "on" that there is air coming from some areas of the roof (I put a toilet paper around and noticed it moves).
2) Is it normal that in only 1 week of using the heat radiator combined with that "extraction" set to off, a laminate flooring gets damaged? Don't you think that there is an installation problem with the flooring as well to be so easily damaged?
As I said, it's a new flat and I'm the first person to rent it so not sure if the laminate flooring was correctly installed.
Thanks for your help.
I have 2 questions:
