Was intending to get my old Potterton Puma combi boiler replaced with a Worcester Bosch 24i Condensing Combi. My CORGI registered installer is worried about the fact that in my top (3rd) floor flat the terminal will be 520mm below eaves that project by a total of 530mm including the plastic guttering.
He muttered something about taking the flue up the wall, making a hole in the eaves and then a hole in the roof above. This would be a prohibitively expensive operation involving three storeys of scaffolding, quite apart from the extensive roof modifications and it would never get approval from the freeholders.
A plume management kit is not an option either as it has would have to have angles and bends in it to take it out past the eaves and guttering; this would be unsightly and also involve scaffolding to get the pipes supported. The fact is that if I am to have the boiler replaced at all then the terminal has to just poke out of the only available hole in the wall where the old Potterton Puma's flue is.
The terminal can not project in a straight line by the 530mm required to get past the overhang as it would then be an unsupported pipe.
There are no other major proximity issues, as the only window within 600mm from the terminal in any direction is the ventilator grille for the old larder now used as the boiler cupboard and this can be blocked up.
So, finally, here is my question: Is my CORGI man right to be concerned or am I right in saying that siting the terminal 500mm below the eaves should be perfectly ok, no matter how much the eaves overhang?
