Condensing Boilers a Waste of Money? Read this article
2 Oct 2007
Sussex
Hi
Thinking about a new boiler. Came across this damming article;
from a reputable website: thisismoney.co.uk
http://www.thisismoney.co.uk/money/.../Are-condensing-boilers-a-waste-of-money.html
If you have the time - is this your experience?
Surely it's not that bad - is it?
If the link above does not work I've included the article below.
(Hope this is not breaking any rules).
UPDATED: 16:44, 5 January 2011
Five years ago, they were heralded as the modern, clean and green way to heat your house. As a result, today there are already eight million 'condensing boilers' in homes across Britain.
In fact, since 2005 it is illegal to fit any other kind.
At the time, the Government claimed they would massively reduce your carbon footprint and slash your fuel bills. As a result, every year some 1.2m old-style 'dirty' boilers are scrapped in Britain and replaced by this wondrous new variety.
However, the recent cold snap has revealed a major problem with them. Tens of thousands of people found themselves shivering as their shiny new boilers cut out without warning.
British Gas is understood to have had 60,000 call-outs in Yorkshire alone. And the cost to call out a plumber? It can be between £200 to £300 on a bank holiday. And don't forget about VAT.
'We've had double the number of call-outs as in the same period last year,' says Charlie Mullins, MD of Pimlico Plumbers in London, the country's largest independent plumbing company.
'It is a massive problem. Some customers were ready to move out because their condensing boilers broke. If I had a choice, I'd put in a non-condensing boiler every time.'
It's all the more infuriating because the problem causing these breakdowns is so simple. In cold weather, the pipe that takes waste water from the back of the condensing boiler — which isn't there in a normal boiler — freezes solid, shutting down the system and in many cases causing permanent damage.
But this problem is just one of many that have plagued this boiler design since they became popular in the Nineties. Many plumbers consider them to be little more than a multi-billion pound con-trick.
In a regular boiler, the hot gases produced when the methane fuel is burned heat water for your radiators, dishwasher, taps and so on. But about 25% of the heat vents out of the exhaust pipe in the form of hot steam and CO2.
In a condensing boiler, a condenser claws back much of the lost heat because as steam condenses into water, it feeds heat back into the system. This can increase overall efficiency from 75% to as much as 93%, and reduce CO2 emissions — and your bills — by a commensurate amount. That, anyway, is the theory boilermakers and politicians want you to believe.
In 2005, the then-deputy PM John Prescott drew up a masterplan to help Britain meet its CO2 emissions targets, as dictated by the 1997 Kyoto Protocol. This involved a new law ordering that all new and replacement boilers fitted to British homes — some 1.4m annually — must from that date be of the condensing type.
A 'boiler scrappage' scheme followed in 2008, which offered people £400 towards the cost of a new condensing boiler if they replaced their old one — even if it was in perfect working order. Boiler manufacturers and plumbing and installation firms could hardly believe their luck.
An estimated eight million homes in Britain made the switch, often encouraged by persistent salesmen who produced an impressive-looking audit offering a seductive assessment of how much money you could save by switching to a new, 'clean' boiler.
But even ignoring the freezing pipe problem, it is clear that in most cases it makes no economic sense to scrap an old boiler that is still functioning.
For an average home, replacing even a very inefficient old model with the best new boiler on the market will, at most, save a couple of hundred pounds a year in gas bills. That sounds good until you realise that at £2,000 for one of the better condensing models, a new one will take at least ten years to pay for itself.
And the problem is that these boilers simply do not last anything like ten years.
'You might get 20 years out of one of the old ones,' Charlie Mullins says, 'but it is more like three to six years out of one of these new ones. In fact, if it goes wrong after four years, you are better off replacing a condensing boiler altogether because of the horrendous cost of the parts.
'On the basis of efficiency, they certainly do not pay for themselves. It makes no sense to take out a working old boiler and replace it with a condensing one.'
That's not something the enthusiastic salesmen will tell you. They also won't tell you that those touted increases in efficiency are theoretical, often not matched in reality. These boilers rarely operate at maximum efficiency anyway.
Explained simply, the water returning from your radiators back to the boiler has to be below 55c for the condenser to condense the steam in the boiler into water. For most homes using standard radiators, this will probably not be the case — the returning water might be as hot as 65c, especially when the radiators are turned up in cold weather.
One impractical 'fix' would be to fit oversized radiators, which can warm the room to the same degree despite being slightly cooler. Another solution would be to fit the latest radiant heating technologies, using pipes embedded in walls and floors.
But fitting these hi-tech systems, which are fairly common on the Continent but rare in Britain, would cost thousands of pounds for most homes.
The problems don't stop there either. The condensed water vapour produced in the new boilers is slightly acidic (as it contains dissolved nitrogen and sulphur oxides), which inevitably causes corrosion of the delicate boiler components and also leads to breakdowns.
So the message is clear: if you have an old boiler, provided it is working properly and is serviced regularly, you are almost certainly better off keeping it until it is beyond economic repair. Parts will be cheaper, it will be less likely to break down and there is no danger of it stalling on the coldest night of the year.
If you're worried about your carbon footprint, just remember that the touted efficiency savings are theoretical figures and might not reflect reality. In a well-designed, well-insulated new home that incorporates the latest heating technology, a condensing boiler might be more efficient.
But most of us do not live in such homes — we have poor insulation and ageing pipes and radiators. Remember, also, that manufacturing each new boiler has a 'carbon cost' in itself that must be 'paid back' by the new boiler.
There is no doubt that the great switch to condensing boilers was motivated by the best intentions. But that's small consolation if you find yourself shivering in a freezing house this winter, wondering when the plumber is going to arrive.
So the first half of your cut and paste rant from a website remarkably similar to the Daily Mail's :rolleyes:
Is people bleating on about a boiler that hasn't been installed properly.
Well I've installed hundreds and only one has ever frozen up.
Plenty of customers have mentioned either lower, or unchanged bills (in in real terms a cut).
I agree ripping a perfectly good boiler out doesn't always make economic sense, but boiler swaps shouldn't be rushed into anyway. Anyone with half a brain will do the simple sums before committing. Anyone that doesn'm frankly, deserve what they get.
And don't get me started on the bullsh-t that is ECO, and the former abortion that was Warm front.
Heat pumps are the way forward, rather than condensing boilers. Our nanny state has made so many ridiculous laws about various things like how many people can sleep in one room to when your daughter cannot share a room with her brother! time will come when they will start to interfere with your reproductive system. It will become a law once you have had a couple of kids to have you sterilized! And when you have reached a certain age and retired, and your children have left home, you must sell your big house and downsize to a smaller property because there aren't enough houses for bigger families, forcing people to install condensing boilers.......
me no way! I have a spare brand new conventional boiler! But may be I will flog it on ebay and get a Heat pump ! :)
There are many old models that last decades but Suprimas and Microns are old school, yet can cost as much as any condensing boiler to maintain.
Should you replace a perfectly good working old boiler? Depends, you can either change it before it start breaking down and leaving you in the cold or you can wait until the middle of winter when it breaks beyond economic repair.
Having said that I've got quite a few 20+ yr old boilers on the books chugging away quite happily.
In terms of reliability there are some lemons out there with condensing boilers as there were with se boilers (ahem suprima ect.)
But there are also a few condensing models out there that I can see still being on my books, chugging away in 20 yrs time.
Will they breakdown yes a fan might go or pcb nothing lasts forever. But for the most part repairing will be an economical option, regardless as to what money bags Mullins has to say.
Will it pay for itself, unlikely with the rising costs of fuel, but setup correctly with good system design, intelligent controls and the best insulation your property can have you will have lower bills .
And as Dan said that major fault is down to poor installation practise at the time, but no one can be blamed in imho. It was before we had those big prolonged freezes and no one really had any idea that it would happen.
The majority of installer now use bigger pipe, lagging ect when going external with condensate, and it isn't the issue it once was.
when the gas boards were sold off it was " tell Sid " now it`s " ask Charley " :LOL:
:) Well thank you all that replied.
Am I any the wiser?
I think so. I was expecting a lot of negatives so I suppose we will have to go for a condensing especially as 'nanny' requires me too eventually.
I was looking at Worcester-Bosch Greenstar (can't we keep anything English?)
I might be back for more info on System Boilers and Unvented Cylinders.
Ouch the price of the cylinders.
Thanks.
Oh No! Another one bites the dust! Happy New year with your new Condensing boiler!
