i dont see a welcome section so ill say hi first ,the user name i use in quite a few scooter forums but i'm richard and i'm from york .....
basically the fool that owned the current house i'm doing (amongst other things like 3 core & earth used for kitchen sockets
has smashed off the original downstairs soil pipe at the inspection chamber and replaced it with a drain for the fall pipe ...and it leaked ...now i have had to cut out the brick work to gain acses to the pipe which entres the main clay soil run ...what connector is avalible in plastic that can be cemented to the socket/flange end(or whatever you call it) and what mix ratio do i use ???
thanks in advance
rich ...ill get a pic up in a bit
thanks in advance
