yea yea cavity as states above.
Was that bit there before or did you edit it in with the linkyea yea cavity as states above.
Was that bit there before or did you edit it in with the linkyea yea cavity as states above.![]()
So choice is;
• Quick/cheap fix - dot & dab 12.5mm square edge MR board, tape joins, prime untilled area & finish skim, tile straight onto the board for the rest.
• Proper way but extended waiting/drying time before tiling can start & rendering more expensive - complete re-render of base, finish skim untilled areas & tile the rest.
If what’s left is firmly attached, you can render & patch repair the rest of the wall up to/around it & then tile or skim over but stripping it all back will make life a lot easier if it’s patchy or there not much left; removal may be better in areas that are to be finished skimmed.for Option 2. - Complete removal of existing render required?
Main reason for my recommending render over Gypsum is so he can tile straight onto it & (without knowing OP's tile preference) maintain maximum tile weight; plaster will knock you back 30%. With a stripped wall in a conventionally decorated wall, I would go with Multi over a suitable Gypsum base plasterRemember though - render is awfully cold.
yes that will work a tight coat of bonding then renderwhat about carbide bodning the exisiting and rendering over?
so your spread went for bonding and render everything still ok? still happy with it?Final update.
Went for bonding and Render in the end and all is good in the world.
Took a while to dry out but all good,![]()
cheers for everyones advice.![]()
