Here we go. I don't often get stumped by something but this is doing my head in. Her we go:
System:
Sealed non condensing combi system with seven radiators all on the same level in a bungalow. All pipe work runs through the loft area and drops to the radiators by way of spurs.
The boiler is a Grant oil fired external boiler that sits at ground level.
The problem:
There is an inconsistent pressure problem in the system which manifests itself by a complete pressure loss only when the system is off. I can charge the system and watch the pressure fall before my eyes until I turn on the circulation pump. The pressure drop then stops instantly. This happens regardless of whether the burner is on or not. The problem started after the pressure vessel had lost all pressure and so had probably blown out through the PRV .
Whats been done so far:
The pressure vessel has been checked and pressurised to 1 bar. The automatic air bleed valve has been checked and is working and not leaking. The PRV has had a plastic bottle under it and has not leaked any water at all.
The only thing I can think of is that there is a leak somewhere in the system but I can find no sign of water loss anywhere and the fact that there is no loss as soon as the pump is turned on leads me to think that it is not a leak.
I am hoping that someone has come across this before and found a solution before I start cutting holes in the plaster board to see if there are any leaks in the radiator spurs.
System:
The problem:
