I have replaced a light fitting from my living room. The light had a dimmer which I replaced with a standard two way swith. On replacing the fitting a noted the wire locations and fitted the new fitting to the ceiling. ( 5 wires in , all reds blocked , all blacks blocked , earths blocked and the switch wired located ).
On refitting and checking the light worked. Until I switched the dining room light. The both lights came on but flickered in doing so and once settled the living room light dimmed considerably.
There are five lights in the circuit and the living room light on works fully when switched alone.
I am real confused as to why this is happening.
Can anyone advise me what to do?
Any advice will be much appreciated
Stu
Stu
