Hello Im looking to install my new electric cooker .
I have added up the following wattage
Hob 5.8
small oven 1.3
grill 0.6/1.7/2.7 low/med/high
main oven 2.0
The total is 11.8 at max but as you cant have the small oven on at the same time as the grill the max is hob 5.8 grill 2.7 and main oven 2.0 total 10.5
The problem is i have phoned belling the manufacture for the model and they have stated that i should hard wire to 6mm cable and use a 32amp fuse.
Reading through this forum i should be using a 45amp fuse and 10mm cable?
Although sparkymike stated somewhere that you apply a diveristy calc?
Thanks Tony
Hob 5.8
small oven 1.3
main oven 2.0
Thanks Tony
