I've removed the old toilet pan and will use a Grohe frame to hang the new one, 1m to the right. This means the soil pipe from the toilet is now about 10cm higher than the pipe to the stack. Both pipes are in a straight line but how to connect them, given that there is a 10cm difference between them?
Pipe is hard against the wall, so I can't use an adjustable bend. I can angle the pipe coming from the Grohe and maybe use a flexible adapter (the type with 2 hose clips) but it just seems a bit clumsy.
