Foolish of you to make that claim when you clearly don't understand a word they say.The wiring regulations are wrong.
Winston
The regulation about supply voltage
http://www.tlc-direct.co.uk/Book/1.1.htm said:For many years the supply voltage for single-phase supplies in the UK has been 240V +/- 6%, giving a possible spread of voltage from 226V to 254 V. For three-phase supplies the voltage was 415 V +/- 6%, the spread being from 390 V to 440V. Most continental voltage levels have been 220/380V.
In 1988 an agreement was reached that voltage levels across Europe should be unified at 230V single phase and 400V three-phase with effect from January 1st, 1995. In both cases the tolerance levels have become -6% to +10%, giving a single-phase voltage spread of 216 V to 253 V, with three-phase values between 376V and 440 V. It is proposed that on January 1st, 2003 the tolerance levels will be widened to +/- 10%.
Since the present supply voltages in the UK lie within the acceptable spread of values, Supply Companies are not intending to reduce their voltages in the near future. This is hardly surprising, because such action would immediately reduce the energy used by consumers (and the income of the Companies) by more than 8%.
In view of the fact that there will be no change to the actual voltage applied to installations, it has been decided not to make changes to the calculations in this book. All are based on the 240/415V supply voltages which have applied for many years and will continue so to do.
230 +10% = 230+23 = 253
There is an "Electrics Outside of the UK" section and this is where this post should have been.
That's interesting - but, from all I've heard, you are in a (probably fairly small) minority. The impression I get is that most UK supplies (like mine) are appreciably higher than that, close to or above 240V. Mine is usually 242V-246V, and I can't recall ever having seen it below 240V.I have measured my voltage a number of times when checking what equipment uses and normally read 233 to 235 volts which OK is a little on high side, but still closer to 230 than 240 ...
I thought that only happened (or was meant to happen) with genuinely 'high' supply voltages - certainly above 250V. Am I wrong? I find it hard to believe that a DNO would reduce a supply voltage which is within the permitted range (i.e. 253V or lower) because of a customer's mal-designed or mal-adjusted solar installation.... and this is likely to be reflected throughout the country now we have domestic solar power. If the voltage is too high then solar power arrays will auto shut down as part of the system that ensures they shut down with a power cut.
