I want to run speaker cable in the expansion gap between the laminate floor and the walls. Where the ends will be visible where the speakers connect in what is the best type of connector to use?
There are more effective ways of ruining the floor, assuming that this is what you're trying to do.sannesley said:I want to run speaker cable in the expansion gap between the laminate floor and the walls.
One that's compatible with the terminal on the back of the speaker?Where the ends will be visible where the speakers connect in what is the best type of connector to use?
Softus said:I detest banana plugs
- the springs weaken,
they tarnish,[
dirt and fluff get in,
they pull out when you don't want them to;
they're just hideous.
Merely your opinion and little use to the OP.oilman said:little use to the OP.
You should be more observant.I have not noticed springs weakening
You should not buy inferior cables.screw terminals don't pull out when it would have saved breaking the cable.
My PVC windows don't fit into speaker terminals.As are PVC windows.they're just hideous.
Fair point.RF Lighting said:Is it so quiet in plumbing that you have to come and argue in our forum?
Softus said:There are more effective ways of ruining the floor, assuming that this is what you're trying to do.sannesley said:I want to run speaker cable in the expansion gap between the laminate floor and the walls.
Leaving aside the fact that you didn't say how many cables, or of what gauge, you were planning to run, my point was that if you fill the expansion gap then the floor can't expand sideways. If you make, or have made, the gap bigger to compensate, then you're not laying the cables in the expansion gap, but in the cable gap.sannesley said:Why would running 2 lengths of 24 gauge speaker cable in an expansion gap ruin the floor
In which case then why not just make the gap big enough to allow both for the cables and for expansion?The skirting board hasn't even gone on yet so now is the ideal time to run the cables.
My personal preference is for speaker cable permanently attached into screw-down posts. If you don't have screw-down posts then crimping on the compatible terminals is equally excellent.The cable from the speaker is 24 gauge cable. I was going to use a flat blade crimp terminal for jointing purposes.
Each to his own.fumbduck said:Banana plugs are fine!p
I wouldn't do that then.I would have no chance of getting my cables into the through holes that they put into binding posts unless I cut my bass cables in half
I'm not, so I don't.If you're really worried (and anal) about it then periodically service them!
Er, but they don't tarnish at the point of contact, whereas banana plugs wiggle, hence they do, which is why you service them and I don't have to....The same goes for screwdown terminals which also tarnish exactly the same
That's because they, like banana plugs, don't clamp on.The interconnects will also thank you for an occasional service of the same sort
Which, if you'll pardon the pun, I can't be ars*d with, hence my desire for quick, reliable, maintenance free connections. After all, I don't peridiocally remove my socket faceplates off and remake all the connections.The persuit of ultimate sound is a finicky and very anal thing
I take your point, and like your style.I'm kinda guessing, since there's only mention of 2 speaker cables, that ultimate audio quality isn't likely (no bi-wiring) so in all honesty I'd go with whatever is easiest. Not everyone likes to grow a beard and put on a hair shirt to listen to a few toones
