Construction Adhesive
6 Feb 2015
Bournemouth
I am going to make some small concrete block planters, only 3 courses high and wide. I understand you can use construction adhesive rather than a mortar mix. Any recommendations as to the best adhesive to use.
All I can say is that construction ashesive is going to be very expensive, not to mention a PIA to use as it is so sticky. What's wrong with concrete?
Well, if you get yourself a tube of GripFill (green), Pink Grip, etc and a caulking gun you'll be able to see for yourself why it is probably an inappropriate material. The water-based versions such as GripFill solvent free (yellow) might be an easier option, but they are still expensive and I'm not so sure that you'll be able to find an effective release compound for your casting form(s)
You'd only really need a blob or two to hold them, so could use cheap silicone.
The planters will need lining to avoid water seeping through
Silicone? Or do you mean MS Polymers?
