Consumer unit and maximum fuse ratings.
you'd be better off renting a small industrial unit... that way you could have room for folding and ironing and such, as well as room for lines for "air drying" overnight..
your domestic supply will not handle 6 x 25A appliances running at the same time and will need to be upgraded..
No way you should even attempt this from a domestic premises.
Even if the electrical supply could be upgraded, you will also require planning permission as you are changing the use of the building.
You are unlikely to get this, as your neighbours are not going to want a laundry next door.
Aye, I'd be looking to spec something like a 3 phase 100A supply for the loading.
Installing new circuits is notifiable under Part P.
Have you looked at using gas for the driers? Do you need an equal number of driers to washing machines?
Yes, using gas is a great option. Then I can only be concerened with 3 radials for the washing machines.
Regards.
Before you go too far on the electrics and/or gas installations give careful thought to the water supply and waste water disposal. You will almost certainly have to notify the local water company to convert your supply to a commerical account.
