I have a garage with an existing consumer unit that has an RCD and existing 32amp MCB\\\'s for a ring main to sockets and a 6amp MCB for lighting circuit. I want to leave an MCB to supply 1 No. external double socket then take a new supply from the CU to pass through a secondary meter and then feed a second CU with a 32amp ring main, 6amp lighting and a supply for an air conditioning unit with a recommended fuse rating of 20amp running at 8amps, starting 8.5amps (inverter driven). My question is what size MCB should i put in the existing CU to feed the meter and new CU? Also what cable size between the 2 CU\\\'s (they will be mounted next to each other.
Any help would be appreciated.
