I am wiring a new built under oven to an existing wall connection point under the worktop. The oven is rated at 4500W max. Can I use 2.5mm T&E? Can a regular round equipment cable be used or must it be T&E?
The circuit beyond the wall point is back to a 30A breaker in the consumer unit via a double pole switch above the worktop.
BTW, is this job notifiable?
