Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
So the cooker had to be disconnected whilst new kitchen units and walls are repaired. Do I need to have a new gas certificate to connect the cooker back up or will the existing certificate do?
Its not a new install ? all the op has done is disconnect the cooker from the bayonet and is connecting it back up again , how is that a new installation ?
A LLGSC is an ANNUAL requirement. Even if you fitted a different cooker or boiler, a new certificate us not required, until the annual date.
If a cert us issued with advice for repairs etc, a new certificate is not required on completion of repairs.
