Hi all,
I know the following is all notifiable and it has been!
I'm installing a new kitchen and trying to organise the electrics for the cooker, hob and other appliances.
I was going to put the cooker and hob on their own circuit protected by a 32A MCB using 10mm T& E. How would you suggest connecting the hob and cooker on the same circuit? Working with 10mm is rather difficult and would appreciate advice on the easiest way to wire both the cooker and hob.
I was going to use a grid switch for the washing machine, dish washer, extractor and water heater (on separate circuit). Can I simply loop in and out of each grid switch as a radial circuit using 2.5mm T& E? As the water heater is on it's own circuit, there will effectively be two circuits within the grid switch. I believe this is acceptable provided there is a warning sticker?
Any advice appreciated.
