Cooker Hood lights/extractor not working, fuse? whereabouts?
8 Nov 2007
East Lothian
Hi all,
the above have both packed in and i cannot locate the plug for the unit. Ive searched inside the hood (under the filters) and also inside the cupboards below the, but cannot find the plug. I also checked nearby cupbaord - but nothing.
Where would i find the plug? Would it be behind the cooker perhaps?
If and when i do find it, is it likely to be the fuse at fault?
Many thanks
Mike
Might not be on a plug, could be on a fused spur unit somewhere. If you follow the cables then you might find it. Depends on the mood of the installer on the day as to where they decided to put it and how :wink:
Could be a fuse, (if it is then I'd ask why it had popped tho), could be a loose connection, could be a faulty switch etc etc.
