Cooker Hood venting. . . .into loft?
15 Mar 2004
I am about to install a cooker hood, and I am looking for some advice.
I live in a bungalow, and its is not possible without great difficulty to vent to an outside wall. Obviously the celing above the kitchen is the loft.
Does anybody know if it is OK to ventilate the extracted air directly into the loft space????? Or is this a big no-no due to the fact that you are. putting moist air into loft therefore causing roof damage?
Eddie M said:
Can you not vent from the loft space to the outside?
Really Its a just lack of skill.... I can fit the hood no problem, but I don't want to destroy the housewall or remove roofing tiles trying to fit a vent to the outside.
The thought of making a hole through a wall from inside to out I think is a little bit beyond me.
You will be amazed at how easy it is. You have used an electric drill to make a round hole, yes? If you go to your friendly local tool hire merchant they will hire you a biggish tool with a "core drill" thats shaped like a baked-bean tin with teeth, that will drill a faultless round hole an exact fit for the plastic tube in your vent kit. It will munch effortlessly through brick.
Once you've got it you'll find yourself drilling such holes for your bathroom, cooker extractor, tumble drier hose, catflap etc because it's so easy.
If your bathroom has no external walls you can drill through a wall in the loft and run trunking to take the steam from the bathroom.
You'll need a firm pair of steps as you'll want to hold it at shoulder height.
Yep JohnD your right, I'm just being a chicken, just didn't fancy drilling a big hole in my lovely house! But I suppose venting damp air into a loft space would do more damage...would'nt it?
yes dont vent into the loft!..... for a start after you cooked fish the whoel place would stink of fish!.. and the moist air woudl rot the beams... core drill, do it properly.
you would also get all the oil and fat thats suspended in the steam and air sticking to all the surfaces and causing as said above the smell and also a fire hazzard
Thanks everybody...your all talking common sense,I was being lazy.......time to get the core drill me thinks
be carefull of any hidden pipes or cables / good luck. r.r.
If you've not drilled your hole yet, why not get carbon filters to fit into your hood, which means you don't have to vent it outside? I think most modern hoods come with the option of both. I think they're about £20 each, and you can probably find them on ebay. I expect it's not as efficient as venting to the outside, but let's face it, we buy these hoods for the look more than their ability to vent, wouldn't you say? I've got one and it seems fine. :wink:
they won't filter out the steam and moisture, and are nowhere near as good, imo, at reducing the cooking smells. As they don't create any suction they don't draw clean air into the kitchen.
you can also buy tile vent terminals, cost about 30-50 quid, and they have a 100mm round spigot with which to attach the vent hose to.
