Hi folks,
Having a 6kW cooker installed and my current unfinished setup looks like this:
Starting at the Fuse Box (not actually connected yet), 10mm cable was channeled through upstairs joists and dropped into kitchen. The drop meant chiseling wall and embedding wire straight into the Cooker Switch (the thing with the Red On/Off switch). This entire run is around 10~11 meters.
Continuing its journey from the underside of the Cooker Switch, the cable is yet again 'embedded' into wall and drops beneath worktop (a further 300mm). Here it opens out (i.e. no longer embedded in the wall) and connects straight into the back of the cooker (with 2 ft of slack in case the cooker needs to be pulled out).
I like to understand these things before calling out pros so wondered whether :
1. A Cooker Outlet plate should be introduced between cooker and switch to facilitate removal/replacement of cooker in the future - as shown below:
2. Whether the cable MUST be embedded/chiseled in the wall by law or can I trunk the bit its not?
3. Any other tips/suggestions?
