Cooker Switch
29 Oct 2007
Devon
Good Morning,
Can I run a built in hob and single oven (13A Oven) from one cooker switch. The current radial is a 30A rated. Both will be within 2 meters. If so can someone please explain the best procedure to complete this, or offer some sound advice
Many thanks
The electric hob should be left on it's own circuit, what is the total loading of the oven, if less than 13 amps and came with a plug top fitted it can be plugged into a socket outlet.
Baz
Thanks for your advice, we have not got the cooker yet but most of the ones she likes are rated at 13A. The thing is I have been told so many conflicting things, one persons say you can one say you cant.
So it is safe to plug cooker into a normal socket, I just need to run a spur from the ring should it be fused??
You need to tell us what wattage the hob and oven will draw. You should get this info from the manufacturers manual or from a plate on the rear or underside of each appliance. Installation instructions are usually provided in the manual.
a cooker has an oven and a hob
Most UK single ovens will run off a 13A plug
Electric hobs use much more than this and must have a dedicated Electric Cooker circuit (this is also adequate for a normal-sized all-electric cooker).
the only normal-sized cookers that will run off a 13A plug have a gas hob and a single electric oven.
