coping stones
18 Aug 2011
Bristol
Hi guys,when you bed coping stones on dpc,is it better to leave the dpc showing or trim it flush
It really does not matter.
It is just a question of appearance and what you are happy with. When building you don't trim it because you don't want mortar bridging the DPC. Afterwards if you have a bit more showing than you would like then feel free to trim it.
Why are you using a DPC under coping stones - it's serving no purpose.
A DPC is not used any more - the copings wont stick
If its a parapet, you might use a liquid DPC, but otherwise no
Whilst the other posters are entitled to there opinions It is good practice to have a DPC below copings unless the coping is a lead covered or a metal section as used as sometimes used at high level.
You should use a bitumen based DPC not the plastic ones ^woody^ is correct that the DPC introduces a weak bond. Generally a bitumen based DPC roll will provide a better bond than a plastic.
It would not be necessary if the masonry below was of an engineering quality.
