    Dismiss Notice
Core cutting 18" thick brick wall..help
Discussion in 'Tools and Materials' started by grandmasterrew, 20 Feb 2011.
  1. grandmasterrew
    grandmasterrew
    5 Aug 2010
    4
    Thanks Received:
    Country:
    Hi
    Im attempting to fit a cooker hood with extraction outside. The problem i have is i live on the end house on the terraced street and the wall im trying to drill is very thick brick approx 18inches.
    The drill bit i used for the guide hole is 400mm long and that doesnt reach outside so the core cutter is definetly too small in legnth.
    Ive seen 200mm extension on screw fix and could be just enough i hope.
    Has anyone else came across the same issue and if so what did you use?
    Any help at all would be great.
  2. RedHerring2
    RedHerring2
    1 May 2010
    2,434
    Thanks Received:
    151
    Staffordshire
    Country:
    Is it just an extension or is it the proper long arbor for core drills?
    If the latter, it's fine.
    I've managed a 250mm wall with the short arbor, so with the 200mm long arbor, you'll just about do it.
    The hole will be large enough to allow a little of the jaws of the drill to go in.
    If not, work from both sides.
    It'll probably be a long hard slog, so make yourself comfortable and safe.
  3. Sponsored Links
  4. grandmasterrew
    grandmasterrew
    5 Aug 2010
    4
    Thanks Received:
    Country:
  5. Burnerman
    Burnerman
    7 Feb 2008
    22,664
    Thanks Received:
    4,422
    Northumberland
    Country:
    You could consider hiring the gear? That way, the hire shop will supply all you need including the drill for around £40.....just knock out the cores as you go and you'll get there.
    John :)
  6. Sponsored Links
  7. Jasonb
    Jasonb
    20 Aug 2004
    2,420
    Thanks Received:
    94
    Surrey
    Country:
    Itwould be cheaper to buy say a 10x1000 budget drill bit to run the pilot right through, open up from teh outside then use the core you have from outside
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
