42 metre run I need to put in prior to a wall footing
to supply garage and green house
will 6mm suffice?
many thanks
Jacko
On the basis of the information you have provided I would recommend 35mm².
42 metres of 35mm² SWA should just about bankrupt you![]()
if you think 35mm is expensive you should buy a few hundred meters of 240mm or larger![]()
at a guess i would say 6mm might be ok but possibly not, thats why you should pay someone to design it, rather than ask for it for free
And/or give you a hernia lifting it in and out of the boot of your car...42 metres of 35mm² SWA should just about bankrupt you![]()
I think he means ask an electrician to specify the design and then they can tell you what cable to use and how they want it installing. It is the spark that has to sign of the installation after all...i have offered advice on here in the past
Is there a pricing structure on here now?
