Correct way to isolate hotwater with a combi
27 Sep 2004
I presume the way to isolate the hot water supply when its fed by a combi with no hot water cylinder, before I undertake a bathroom refit is to turn off the main cold stopcock and then isolate the boiler electrical supply? Thanks.
Seems though nobody has replied....
Yes!
However, don't isolate below the boiler (on the jig) as they almost always leak!
Hot water sequence begins with a flow of water. If you prevent the flow, we have no sequence.simples.
