Corrugated iron roof
29 Dec 2008
Herefordshire
At this time of the year, winter, when the sun comes out the underside of my garage roof, exposed corrugated iron sheeting, attracts considerable condensation and the constant dripping saturates everything below.
Does anyone know how I might line the underside of the roof (preferably without a major effort!) to remove the problem?
Mmm, not always then either. I've got several structures that are basically open-sided barns with tin tops, and on heavy dew days they drip heavily too. Worst is cold, still mornings after warm days.
The insulated tin sheeting certainly does help since it reduces the coldness for the moisture to condensate on, but it ain't cheap.
Not tried it myself, but I imagine plenty of insulation followed by vapour barrier followed by a ceiling board of some description would do pretty well the same job in retrofit.
A metal roof will always have condensation on it, think you need to either live with it or replace it with a polycarbonate roof or similar.
What do you use the garage for?
Thank you everyone for your replies, they have helped to clarify my mind as to what I may have to do about the problem. I was hoping there might have been a bitumen paint or something I could have coated on to warm up the surface. It is all about temperature differences, of course, and the air, plenty of which comes in throught the double doors. I may have to suspend plastic sheeting or something to capture the constant drips (it's a sloping roof) and direct the streams to an internal gutter. Hillw, I keep everything (all highly imporant and useful stuff that only men appreciate) in there which my wife won't have in the house, so sometimes it's quite a struggle to get in.
Sounds the same as mine!!
Was goign to suggest a polycarbonate roof, as the twinwall type would reduce if not stop condensation totally, but it would mean a total re-roof, not sure if you are up to that?
Good thinking, Wreckedit!
But wouldn't it be better to ludl the chakcer on the lutterbud bestwif? Nimfy futtie.
