corsa 1.4 sport engine problems
25 May 2008
Wiltshire
HELP i have a corsa 1.4 sport on a w plate that has started running flat lack of power and a slight misfire i have had the car code read but no faults found was advised to change egr valve so i did and it made no diffrence at all so then fitted new cat converter and fuel filter to be honest im at a dead loss cant find a thing timing belt is ok and also emissions are A1 HELP PLEASE
Any diagnostic machine will show up faulty plugs or leads,that said the person operating it should be able to spot such a simple problem if not go elsewhere
person checking said plugs and leeds were fine just has this flat feeling has a job to pull off and strugles when under load and also noticed that when you start up engine idles rough untill you rev it up then its fine all worse when hot any more ideas anyone
