Cost for concrete base for wood garage
Discussion in 'Building' started by pg325, 12 Jan 2014.
  1. pg325
    pg325
    13 Feb 2005
    42
    Thanks Received:
    Country:
    I'm thinking of having a wooden garage erected next to the house on a concrete base.
    It's only to store a car so I'm hoping a 100mm slab on top of some hardcore will suffice.
    I know the cost of the garage but want to calculate the cost of having the base constructed.
    I can do all the digging but I'd really like so indication of hardcore and concrete costs for 20 x 10.
    Any ideas.
  2. Sponsored Links
  3. noseall
    noseall
    2 Feb 2006
    43,932
    Thanks Received:
    2,717
    Staffordshire
    Country:
    150mm (5.5 tonne) of stone, wacker, 2m³ of concrete etc will set you back aboot £400 - £500 depending how and where you shop.
    Other things to consider are spoil removal, excavator costs, polythene dpm, shuttering, rainwater drainage, slab toe and edge thickening, reinforcement, slab protection etc.
    However, much thought needs going into these type of bases, if you are to avoid damp ingress problems later on. In particular your method of base construction and the pitfalls associated with economy slab bases.
    There are a billion posts on the subject if you can be bothered with the search facility.
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
