- Joined
- 27 Jan 2008
- Messages
- 29,928
- Reaction score
- 3,729
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I looked at the power being used yesterday, between cups of coffee, running freezers etc, we ran out of battery.
In the main it is the little things not the major ones, I do think my wife ran the dish washer late, which has not helped, the three spikes, but the 816 watt spike, I can't explain, freezers use around 60 watts when running, and have 4 of them so lights, TV, and central heating and my laptop, but that does not equal 816 watts, I looked at smart meter, but as yet yesterday not shown. And anyway ½ hour blocks don't really help.
I am not seeing a use under 150 watts, the 1kW spikes and over I can explain away, and it seems likely with 4 freezers that at any one time, one of them is running, so expect 60 - 250 watts, which means I have something running which should not be.
I have tried the clamp-on around the meter tails, and turning off the RCBOs one at a time, and it does seem the main house rings are to blame, but turn them off and back on, there is always a spike and it will also turn on any smart bulbs etc.
Only one freezer is powered from the consumer unit, other three are on the EPS, and the one which is from consumer unit is in the flat, so not either of the two ring finals for the house.
I can see stand-by will be some of it, but all have a 1 watt limit, so still not enough to explain the use. My bills are not high
so not really worried about the bill, just wonder where it could be going?
In the main it is the little things not the major ones, I do think my wife ran the dish washer late, which has not helped, the three spikes, but the 816 watt spike, I can't explain, freezers use around 60 watts when running, and have 4 of them so lights, TV, and central heating and my laptop, but that does not equal 816 watts, I looked at smart meter, but as yet yesterday not shown. And anyway ½ hour blocks don't really help.I am not seeing a use under 150 watts, the 1kW spikes and over I can explain away, and it seems likely with 4 freezers that at any one time, one of them is running, so expect 60 - 250 watts, which means I have something running which should not be.
