Cost of little things, like reheating cup of coffee?
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
I looked at the power being used yesterday, between cups of coffee, running freezers etc, we ran out of battery. 1795351345649.pngIn the main it is the little things not the major ones, I do think my wife ran the dish washer late, which has not helped, the three spikes, but the 816 watt spike, I can't explain, freezers use around 60 watts when running, and have 4 of them so lights, TV, and central heating and my laptop, but that does not equal 816 watts, I looked at smart meter, but as yet yesterday not shown. And anyway ½ hour blocks don't really help.
I am not seeing a use under 150 watts, the 1kW spikes and over I can explain away, and it seems likely with 4 freezers that at any one time, one of them is running, so expect 60 - 250 watts, which means I have something running which should not be.
I have tried the clamp-on around the meter tails, and turning off the RCBOs one at a time, and it does seem the main house rings are to blame, but turn them off and back on, there is always a spike and it will also turn on any smart bulbs etc.
Only one freezer is powered from the consumer unit, other three are on the EPS, and the one which is from consumer unit is in the flat, so not either of the two ring finals for the house.
I can see stand-by will be some of it, but all have a 1 watt limit, so still not enough to explain the use. My bills are not high
so not really worried about the bill, just wonder where it could be going?
Smart anything = uses power continuously.
Small amounts individually, but with dozens or more of these things, it's not trivial.
4 freezers can easily become one.
you mention reheating coffee
unless it contains residual heat it probably be more expensive to micro over boiling a kettle as 100% in a kettle turns to heat with only the connected losses off perhaps 5 to 10% in warming the kettle where as a micro is perhaps 25 to 40% transmission losses[magnitron light and turntable]
and yes i am assuming you kettle can boil a single cup and you may waste the milk and coffee as it cant go in the kettle ;)
and as flameport say smart anything uses power even on standby
i have 3 tvs and 2 freeveiw boxes and all are purposely in dumb mode and not internet connect as it can double the small amount off power they use
for example the 32" tv uses 12w and initially when i first got it i set it i set it up on the internet just to see what it does and random checking when not using it as anything other than a monitor it would randomly go anywhere between 15 and 26w and even when on low power standby where it should be sub 1w it would go anywhere between 3 and 10w
i had to "factory reset" to get back to 12w and unplug when not in use
and before you say its hardly worth it you are correct lol buuuttt as my summer base load is only 2500w or105w an hour so iff my 5 smart items say average 5w each that 25w an hour or 24% more basic consumption;)
I look at the minium today 164 watt, I would assume all my smart stuff will not turn off, so that 164 watt should cover all the smart stuff.
So the peak of 672 watt, not counting the microwave, kettle etc, which show clear peaks of 1.5 kW or more, I am trying to place the 508 watt between the two, the evening low point 264 watt, so TV + Laptop + lights + boiler = 100 watts it would seem, so the freezers it seems likely around 60 watt each, so 300 watt, so I have 200 watt, which is not accounted for, it must be some thing which switches on/off, once I have an idea what it may be, I can put an energy monitor on that item as check it, it is only 200 watt, so no big thing, but it just niggles me, trying to work out what.
1795383741343.png The monitor, TV, etc, should run for longer, ignoring the 4 peaks when cooking or making coffee, freezers run for at least ½ each time they run, so would expect a square wave not a lot of peaks and troughs.
For 200 watt, I don't want to remove the cover off the consumer unit and stand there holding a clamp-on meter, I know it is something on the ring final circuits, by switching them off, so more down to what on the ring final circuits can cause all the spikes.
I look at the cost of dumping cold coffee, and making new, against reheating in the micro-wave, not only coffee, but other food. If I use an oven, air frier, ring etc, it is thermostatics or mark/spaced controlled in some way, but in the main the microwave is either on or off, so putting a potato to bake in microwave first ensured it cooked all the way through, and finished off in the standard oven with the pizza gives a baked skin and is far faster to doing it all in the oven.
But if heating the oven anyway for the pizza, is it an energy efficient method?
The same with the air frier, we are heating less metal work, to using a standard oven, but what about a twin draw air frier.
It is also going to affect taste, I have tried filling a flask of coffee. Theron OK, practice, it has a metallic taste, same not boiling water to make coffee, it does not taste right, even with instant coffee.
The same applies with domestic hot water, I know I am loosing heat in the pipe work cylinder to taps, but I have 5 rooms with hot water, to have 5 hot water stores does not really make sense.
However the pipes boiler to cylinder in the summer, better to keep cold and not use boiler, and use immersion heater instead, but winter, any heat lost from pipes, goes into the house anyway, so in the winter I use the boiler.
I hope by talking about it, some one will point out errors etc.
This is not the first time I have tried to work it out, see here
Solar panels/ turbines/ ground or air source heat pumps that serve groups of houses must be the way forward. No, or cable based, Internet which minimises foreign interference. Warm as much coffee as you want.
Not sure, I am aware today my solar is low, not helped by wife setting off the three large machines late. Just 13% left at 3 pm, so will run out today.
1795532303579.pngLlwyngwril on the coast of Mid Wales I remember the hum of the generator around here somewhere, likely originally water powered, but by time I remember it was a 110 volt DC diesel generator, supplying the village and outlaying farms.
Not being the same standard as rest of UK, resulted in problems, may be had it been a 230 volt 50 Hz supply it would have lasted longer, I will guess I was about 10 year old, so 65 years ago they got grid power, 20 Dec 2008 was last village in Wales to get grid power, so we have not long ago finished the grid, so to then return to small generators does seem a backwards step.
The standing charge however, does not help, with no standing charge, 2024 I just produced more than used, 2025 and 2026 so far, I have produced a lot more than I have used, 2025 consumption 4947.9 kWh and production 6028.8 kWh add that I used off-peak so nearly ½ my bill 1795533614404.png is down to standing charge, that how much continuation of supply costs. £244 per year to be able to use the grid, if it was not for the standing charge my electric bill for the year would be a negative figure, as it is only just over £100 for the year, but the whole reason for this thread is I am using more than I should be, if I was sharing the bill, likely would not be worried.
So what is using the unexplained 100 watt.
putting a potato to bake in microwave first ensured it cooked all the way through, and finished off in the standard oven..
I've seen that idea before. I've tried doing jacket spuds just in the micro, and they were not good, but I'm open to being convinced about the 2-stage method, so next time I'll try to remember to do one the "proper" way, and one the hybrid way, so the potatoes will be the same, and I'll do a taste test.
My first thought when I saw the title...
