    Dismiss Notice
Could you put a wireless PIR in your car?
Discussion in 'Alarms, CCTV & Telephones' started by britishboy7, 17 Jan 2016.
  1. britishboy7
    britishboy7
    31 Oct 2015
    271
    Thanks Received:
    Country:
    Random I know, but could you put a home wireless PIR in your car on the drive, so that it activated your house alarm if anyone broke into your car? or would that not work?
    Was thinking for the 2nd car that only goes out once every couple of weeks, it is alarmed but not a great alarm on it, just wondering if a wireless PIR for my Visonic Powermax would work just sat somewhere in the car, in one of the front footwells facing upwards for example?
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,383
    Londonderry
    Country:
    If you can have them remote in the garage/outhouses, I cannot see why they would not work in a vehicle parked on the driveway.
    • Thanks Thanks x 1
  4. bernardgreen
    bernardgreen
    3 Nov 2006
    24,631
    Thanks Received:
    2,419
    Bedfordshire
    Country:
    It would be OK in a system which only has one way communication ( alarms from sensors to panel / siren ) but would present a problem in a system using two way communications where the panel routinely checks that all sensors are in good condition. When the car and its sensor were not at home the system's routine check of it's sensor would report a sensor failing to respond and thus an alarm indication would be raised.
    • Thanks Thanks x 1
  5. britishboy7
    britishboy7
    31 Oct 2015
    271
    Thanks Received:
    Country:
    Thanks Bernard, I thought that and as the car is only a 2nd use car, I would just remove it from the footwell (or wherever you guys think the best location in the car for it) and sit it in the house by the control panel (under the stairs) so the system does not think its 'lost' a sensor
  6. bernardgreen
    bernardgreen
    3 Nov 2006
    24,631
    Thanks Received:
    2,419
    Bedfordshire
    Country:
    Buy a **** wireless alarm and the system won't care if the sensor is on the drive, on holiday in Bognor Regis or gone with the car to it's new owner.
  7. OwainDIYer
    OwainDIYer
    5 May 2010
    4,533
    Thanks Received:
    694
    Stirlingshire
    Country:
    Check the power consumption - the PIR might drain the car battery. And PIRs might not be happy with the 14 volts or so from a car battery.
  8. JohnD
    JohnD
    15 Nov 2005
    69,809
    Thanks Received:
    3,935
    Crossgates
    Country:
    Cook Islands
    Wireless PIRs commonly have no wires, and run on internal batteries, which commonly last for a couple of years.
    • Like Like x 1
  9. Sponsored Links
  10. Twenty Four
    Twenty Four
    23 Sep 2015
    167
    Thanks Received:
    6
    Country:
    :D:D:D:D
  11. ibruceuk
    ibruceuk
    11 Jun 2005
    185
    Thanks Received:
    17
    Lancashire
    Country:
    I was thinking of doing this with my Galaxy for both our cars as I have a couple of spare wireless mags lying around and both cars have an 'alarm activated' output that I can wire through a relay to the reed switch. Obviously I would disable supervision on these so it shouldn't matter if they get moved out of range.
  12. britishboy7
    britishboy7
    31 Oct 2015
    271
    Thanks Received:
    Country:
    It was just a thought really, these scummy parasites who get into peoples cars probably think they're smart getting round a car alarm or unlocking it, but will hopefully run a mile if the house alarm starts screaming at them the moment the car door is opened
    Would a wireless PIR detect someone walking past the car though? Through the glass?
  13. sparkymarka
    sparkymarka
    16 Feb 2011
    8,444
    Thanks Received:
    1,283
    Sheffield
    Country:
    No
    • Thanks Thanks x 1
  14. OwainDIYer
    OwainDIYer
    5 May 2010
    4,533
    Thanks Received:
    694
    Stirlingshire
    Country:
    I suppose you coul ddo it that way, yeah.
  15. britishboy7
    britishboy7
    31 Oct 2015
    271
    Thanks Received:
    Country:
    Thanks all, I will give it a try. Can you set up the Visonic Powermax Complete to not routinely check 1 wireless PIR, even if 6 or 7 others are constantly checking back to the controller?
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
