I am about to purchase a 1925 property, it is brick built with a cavity which has had cavity wall insulation added. I am planning to hack off the exterior walls and then batten and board them so i can hide various services (pipe work and cables ect). My main thaught is weather or not i should take this opertunity to add some extra insulation in the form of bubble foil insulation. I plan to tack this to the battens and fix plasterboard directly over. My main concern is that I may cause condensation on either side of this bubble foil due to temperature differences. Is this likely and can anyone see any other drawbacks from doing this.
Thanks for reading and thanks in advance for your replies
John
John
