My really old downstairs toilet (mains water pressure) was constantly overflowing so much so it over-whelmed the overflow.
After turning the water off (no isolators) I opened it up and the float valve was the old part 1, ball float in poor condition and appeared the valve leaked. As the valve was pretty corroded rather than dismantle the thing, washers perished, etc I thought it would be easier to just replace valve with a part 2 valve and new ball . It was simple to replace, and no leaks.
My only query was the copper pipe was originally coupled with a nut but did not look like a normal compression unit with olive. It looks to be a seal (maybe rubber) at the end of 15mm pipe and tightening the nut to the float valve thread pulls / joins the pipe to the valve and seals the unit. I put some PFTE tape in there on both threads and turned spanner until tight but I wasn't sure how this seal would work or fail!
As I have not seen this type of fitting discussed I just wondered whether it got replaced - e.g. it is rubber and at some point will fail!
Ashley.
Ashley.
