cut unknown wire in loft. what to do?
3 Jun 2010
Blackpool
i think i nearly just killed myself. i have just cut a wire in my loft and in a result tripped out all the upstairs lighting in my house.
Can i fix this by connecting it back together with a terminal block.
The wire Contains 4 wires.
1 brown live
1 black neutral
1 earth
1 grey ?
im not sure what the grey wire is for?
so basically i need advice if this will be ok all connected back together with a terminal choc block? or do i need to fix a new wire up there?
what amp choc bloc?
do i need to cover the terminal block with anything else light insulation tape etc as it is in the loft amongst fiber glass insulation?
im 23 years old i did a 1 year course in electrical insulation, very basic, learnt how to wire lights, sockets etc never come across this wire before but thats probabily because i dropped out to persue another career but i feel confident i can fix this with you expert advice. thanks.
ps - i know im a lucky boy thank god the fuse tripped
Why should it be blue? It sounds like standard three core and earth to me - brown black grey.
The black must not be assumed to be the neutral - it could just as easily (and more likely) be the grey.
Could be a fan, could be two way switching, could be anything.
Err, yes, sorry. Not entirely here. :)
Whatever it is, joining it should be fine.
great il get down to b&q tomorrow get a 15a connector and connector box. thanks for the info. still cant belive how lucky iv been!
which is better/safer. dont want the loft burning down the house 2+ years down the line
as an aside
if its to board your loft then it needs to be accessible like any other screw join
