Cutting a square hole
24 Nov 2007
Cambridgeshire
I have a woodedn 1/2" ply board screwed to 1" battons, the board can't come off the battons but I would like to make a 6 x 6 square hole in it.
The board is to shallow for my jigsaw, or pad saw and chain drilling would neen a fair bit of work to tidy the edges.
What would the pros use to make a hole in this situation.
Ta
:idea: Screw another piece of ply over the existing as to make the blade plunge deep enough. :idea:
when you saw jigsaw i assume you mean the frame of you hand held jigsaw wont reach
some options
power jigsaw
chinese saw
large hacksaw blade and lots off tape to make a handle
oscilating saw like the bosh 180e
floor board saw
some options need a hole drilled in diagonaly opposit corners
Thanks for the replies,
Like the look of the link but its a tadge expensive.
If my chosen option doesnt work for me I'll look into the other saws.
Building up to allow the depth to be right is a great idea and one that I will go for.
Cheers
cut a jigsaw blade down to the correct depth.
i did this last week to cut new in-situ plaster board on irregular exisiting rafters to make sure i got the cuts exactly centre of the rafter.never done it that way before but is so easy.
Router with jig and template cutter.
or, as it's plywood, you could score the opening with a ruler and very sharp knife, and then pare back the ply a layer at a time using a sharp chisel.
that Exakt Saw looks like an accident waiting to happen :shock:
i use the same method for floor boards as long as you go at a steady pace with pendulum on they cut just fine
if you push too hard the end off the blade will bounce off the top as its a 22mm blade on a 25mm stroke
Chukka/Big-all
Gents,
How do you start the cuts ? I can visualise whats happening once you get going albeit a bit scary as the blade clears the workpiece on each stoke!
I would image a little practice is needed to get the pace right.
Do you cut the blades down with an angle grinder steel cutting blade or something else
cut the blade down with a hacksaw,you'll be surprised how soft the blades are.drill a hole to start your cut.insert the jigsaw blade,keep firm pressure on the jigsaw all the time.
