Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have a diamond wheel wet tile cutter and it says you can use it to cut holes/recesses, but it doesn't say how. I need to cut a rectangular hole for wall mounted taps in the centre of a 10mm porcelain tile. Anybody got any tips on how I can do this?
the way to cut the centre of a tile without going throught he edges is simple, place the tile on top of the wheel, (as its moving preferably) you will need to take out the guard as it will get in the way.
