B+Q Electric Diamond Wheel Cutter - will it cut porcelain
15 Feb 2008
I have a B+Q electric tile cutter. The box says it cuts ceramic, terracotta, slate and marble. It has a diamond cutting wheel (MPA-Z-05480).
Is this likely to be able to cut porcelain floor tiles as well ?
I know that I need something with a diamond wheel, but I don't know if there are different grades of diamond wheel, some suitable and some not.
Many thanks.
22 Sep 2005
Preston, Lancashire
Yes it should do. Porcelain is pretty tough so a cheapo cutter might "complain" a bit, but it should work.
11 Dec 2006
Leicester
just remember to take your time and run the tiles through slowly, then you should have no worries
15 Feb 2008
Gcol and Jefoss, thanks guys for your replies. Will treat it gently.
Doesn't matter too much if it doesn't stand up to lots of use (don't expect it to for £20). First time I've done any tiling, and probably wonn't do any more until I next move house.
