I need to cut through some plastic piping (the thick terracotta stuff you normally see outside) which is cemented into my bathroom wall. Its the vent for the old extractor fan but my new fan needs to be sunk in about 60mm. I would like to keep the same pipe as the dimensions are just right and besides I already tried to remove it in the past and its stuck fast.
Whats the best way to cut 6cm of the pipe out? Was thinking of buying a dremel just for the job. Do you think that would work?
Thanks.
Thanks.
