Slacken any clips or remove covers and put a claw hammer behind it and pull it out from the wall a bit to get the pipeslice in. If pipeslice is tight to turn, use a pair of grips to turn it. Otherwise just use a junior hacksaw.
Took longer to type this than it would have to cut the pipe
The best tool for this job is the Fein multi tool every plumber should have one,its like a get out of jail card
The amount of time it saves on jobs like close pipes cutting floor boards tight to the wall and countless other uses ,even cheap bisch version is excellent
Fair enough amz i use to think the same until i bought one ,time is moneyand how much it saves most of our work is priced not day rate so quicker we can get it done quicker we on to the next and i will buy the right tools if they help to speed up my work
