    Dismiss Notice
Cutting porcelain tile
Discussion in 'Tiling' started by Blunda, 13 Jul 2010.
  1. Blunda
    Blunda
    17 Jul 2007
    97
    Thanks Received:
    Kent
    Country:
    Hello
    I have boxed in my toilet and I would like to tile it. The problem is I am using porcelain tiles and Im not sure how I am going to cut the hole for the flush?
    I dont want to have to go out and buy a spcialised tile cutter for just one hole so was wondering if there was a jigsaw bit I could use which would do the trick for one hole? surely it would work if i squirt water on it aswell?
    Sorry if that sounds dumb! if so, educate me! :)
  2. jctilingservices
    jctilingservices
    29 Oct 2009
    1,195
    Thanks Received:
    150
    Tyne and Wear
    Country:
    to be honest with you mate, the chances of a cheap diamond bit NOT burning out is minimal.
    I can make a suggestion to you if you really dont want to buy a decent bit
    Mark on the front and back of your tile where you want your hole and the size, then cut through from the back with a diamond tipped disc on a grinder, once you got the hole near enough the size you want, use a tile file to file the hole round, thats probs your cheapest option, unless you know a tile fixer who might drill it for you
  3. Sponsored Links
  4. Blunda
    Blunda
    17 Jul 2007
    97
    Thanks Received:
    Kent
    Country:
    So if i did have the money to buy a decent diamond drill bit how would I cut the whole then? because it wont be a small whole. How much would I be looking at spending on a decent bit?
  5. jctilingservices
    jctilingservices
    29 Oct 2009
    1,195
    Thanks Received:
    150
    Tyne and Wear
    Country:
    sorry the reply is late mate, if you give me the size of the hole you need to make i will be able to give you an idea of the price you would pay
  6. Sponsored Links
  7. tictic
    tictic
    6 Oct 2009
    1,419
    Thanks Received:
    173
    Glasgow
    Country:
    why dont you just hire a diamond core bit from HSS or the likes...as you have said its only one hole.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
