dado
You will have to return the horizontal rail around the corner for a short distance, and then mitre the angled dado into this.
At the minimum, set the angled dado back so that the line of the top of it meets the horizontal one at the wall corner. Then you have the length of the horizontal one which is returned around the corner, and then you just half the angle of this and the angled dado to get the mitre angle
yep as woody says you need to deal with the horizontal [corner]join then the stair angle
so you either need too raise the stair line 3 inches or so and change the diagonal around the coner on the level
or lower the stair line and change to level just before the corner on the stairs
you cannot easily deal with changes of directions in 2 planes at once [its nearly impossible but not quite ;)
I wonder if it would be better/easier to fix a corner block on the stair side of the wall and just cut the two dados to this?
Something like one of these ...
This was my suggestion Woody, but he just wanted to come and get more advice. Although the block is another option, and a good one at the but if i was to do it i would have one on either wall to even it all up! good advice guys and thanks for replying to my mates ?
Noodles
Probably way too late but
IF the angle of the stairs is 45° you'd cut on the 22½ °degree bit on the mitre box.
