Damp/condensation new build detached garage
2 Jan 2022
Hi
sorry if this is a over discussed topic, new to this.
We have a new build detached garage. Main door the only opening, no vents in soffits. Ceiling not plaster boarded.
since winter began it has got ridiculously damp through condensation.
I painted the floor in summer which stays dry.
what is the best option as all my soft wood or material possessions are covered in mould already
15 Nov 2005
Crossgates, Europe
Cook Islands
add ventilation at the top of the walls or under the eaves or in the gables if you have them
water vapour is lighter than air so will naturally rise within the garage
check all the gutters downpipes and drains to ensure that rainwater is led away from the building and does not splash on the walls
check the roof for leaks
walk round the outside to check for damp patches or earth bridging the DPC
can water enter under the door?
does the concrete floor have a DPM?
2 Jan 2022
Thanks. I have sealed the bottom of the garage door. Floor has dpm.
I’ll go for the eaves vents. Cheap and easy. Thanks. I have complained to Morris homes but can’t see them doing owt
3 Sep 2006
West Mids
A garage is for a car, to keep the weather off - a walls and a roof, and security - a door. That's it, not for storage. There are no regulations to prevent dampness or ventilation
5 Jun 2019
I’m sure you need air vents in a garage for the fumes if you plan on using it for a car.
2 Jan 2022
Not for a car but all my shoes, boxes etc are covered in mould and it’s only been cold a few times
3 Sep 2006
West Mids
It doesn’t. There needs to be some flow to push the stale air out, in my case the cold air causing damp.
My reply was to the quoted text.
But your understanding about condensation and stale air is flawed.
Condensation is caused by air, any air coming in to contact with cold surfaces. Nothing to do with stale air or ventilation, and in your case everything to so with that mass of cold garage walls and floor.
If you go outside on certain days, spring, summer autumn, winter, you will see condensation on the outside of car bodywork, car glass, bus shelters, steel structures you name it. And you wont get any more ventilated than the outside air!
