Danfoss Bho 64 control box
1 Dec 2010
Carmarthenshire
Quick question,I have a Danfoss BHO 64 control box which needed replacing as it was not bringing in the solenoid,everything else is working (spark etc) I have had a equivalent replacement part but when fitted the opposite happens i.e no spark but the solenoid kicks in.My question is re the base wiring does it need to be modified to suit the new control box as some of the contacts in the new box are slightly different.
What model ref is your new box?
It is easy enough to check the base terminal wiring with the wiring diagram on the old base.
Thanks Oilhead for your reply, the new box is the one recommended as a direct replacement for the original.I have moved one of the terminals in the base to suit the new control box and it's now working.Thanks again for replying.
Cheers.
